Can no longer change User/PW - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Can no longer change User/PW (/showthread.php?tid=8423) |
Can no longer change User/PW - mookiebud - 08-07-2025 Board Model: KC868_A16 Software Version : v2.2.14 Build Date: Jun 26 2025 07:36:40 Web interface on Ethernet .... Originally I was able to change the user name and password. However, at some reasonably early setting changes, the KC868 stop responding over Ethernet. I noted the port actiivity seemed to be intermittent. In other words, the activity lights would flash for perhaps a second and then turn off. The board seemed to be in continuous reset? Anyhow, I decided to re-flash the FW (with the same version above). That appeared to be successful and permitted me to login with the default UN/PW (admin/admin). However, the minute I went to change the 'System', I immediately was presented with the login screen again. Several repeats later, ie, I login, go to 'System', login, go to 'System' I figured maybe an 'ERASE' cycle with ESP's firmware tool would help .... it didn't. Why can't I now change the User Name and Password even though I could on the initial configuration. PS: Clicking on the upper right 'Admin' -> 'Change Password' has the same cycle of repeatedly asking for login info. TIA. RE: Can no longer change User/PW - admin - 08-07-2025 clear your web browser cookis or change a web browser. RE: Can no longer change User/PW - mookiebud - 08-07-2025 (08-07-2025, 02:38 AM)admin Wrote: clear your web browser cookis or change a web browser. sometimes you forget about the most obvious solution ... appreciate the gentle remind
RE: Can no longer change User/PW - admin - 08-07-2025 you are welcome. RE: Can no longer change User/PW - willsmith - 11-26-2025 Full factory reset — check if there’s a hardware reset button or a specific reset procedure that clears all settings, not just the firmware. |
