No AP appears - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6 (https://www.kincony.com/forum/forumdisplay.php?fid=22) +--- Thread: No AP appears (/showthread.php?tid=8446) |
No AP appears - sergey1945 - 08-13-2025 I just bought the KS868 A6 board and successfully flashed the firmware according to the instructions. However, after reconnecting the power, I can't detect the Wi-Fi access point. When power is applied, the red LED near the power connector lights up, and all relays click. No other activity on the board. Tried firmware KCS_KC868_A6_V2.2.13 and KCS_KC868_A6_V2.2.14. My board arrived in a very dented package, so I'm concerned about the Wi-Fi module. Is there any way to diagnose the Wi-Fi module? Could this issue be related to me temporarily using a DC 12V 1A? RE: No AP appears - admin - 08-13-2025 can you take photo , how you wire your board. usually we suggest use DC12V 2A power supply. RE: No AP appears - sergey1945 - 08-13-2025 (08-13-2025, 01:37 PM)admin Wrote: can you take photo , how you wire your board. RE: No AP appears - sergey1945 - 08-13-2025 Plugged the board into a 2A DC adapter, but the hotspot didn’t show up. Plugged the board into a 2A DC adapter, but the AP didn’t show up. RE: No AP appears - admin - 08-13-2025 because you have not downloaded firmware, you have not selected first row. see my photo step3: enable item.
RE: No AP appears - sergey1945 - 08-14-2025 Oops, my bad—missed that line. Always double-check the instructions! Thanks for saving me! |
