DI8 i2c io expander - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=62) +--- Forum: F16 (https://www.kincony.com/forum/forumdisplay.php?fid=63) +--- Thread: DI8 i2c io expander (/showthread.php?tid=8476) |
DI8 i2c io expander - ystefanov - 08-30-2025 Can the DI8 i2c io expander be used with F16? RE: DI8 i2c io expander - admin - 08-31-2025 sure, if you config by ESPHome. RE: DI8 i2c io expander - ystefanov - 08-31-2025 How would you connect them? Is there an i2c connector on the F16, I didn’t see it on the images? RE: DI8 i2c io expander - admin - 08-31-2025 see the photo. RE: DI8 i2c io expander - admin - 08-31-2025 another way, you can use any free gpios define for i2c SDA and SCL pin. RE: DI8 i2c io expander - ystefanov - 08-31-2025 Thank you!!! |
