RS485 communicattion - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=66) +--- Forum: G1 (https://www.kincony.com/forum/forumdisplay.php?fid=67) +--- Thread: RS485 communicattion (/showthread.php?tid=8620) |
RS485 communicattion - SixSixOne - 10-02-2025 Hello again, I have one KC868-G1 and one KC868-AI could you please assit on how to connect each other with RS485 connection and use the G1 to read all digital inputs from the AI in home assistant. The reason I need RS485 is for redundancy in case network drops. Thank tou Dimitris RE: RS485 communicattion - admin - 10-02-2025 can you take an example? RE: RS485 communicattion - SixSixOne - 10-03-2025 I do not know how to setup KC868-G1 as Modbus-master and KC868-AI as Modbus slave in order to receive to KC868-G1 all digital input status of the KC868-AI. Could you please give some instructions as there is no setting in the web interface for master/slave declaration. Otherwise please advise yaml example forr master/slave in ESPhome if possible. Appreciate a lot Dimitris RE: RS485 communicattion - admin - 10-03-2025 KCS firmware only use pcb as "SLAVE". if you want use by "MASTER", you can config by ESPHome. check with ESPHome online guide. RE: RS485 communicattion - SixSixOne - 10-03-2025 (10-03-2025, 06:22 AM)admin Wrote: KCS firmware only use pcb as "SLAVE". Are you planning to include "master" function as well in the future? It will be very helpful. Thank you RE: RS485 communicattion - admin - 10-03-2025 now not have the plan. suggest config by esphome. |
