Sauna automation with Loxone and Kincony - Printable Version
+--- Forum: KinCony integrate with Loxone home automation (https://www.kincony.com/forum/forumdisplay.php?fid=19)
+--- Thread: Sauna automation with Loxone and Kincony (/showthread.php?tid=8629)
Sauna automation with Loxone and Kincony - Hakuna23 - 10-05-2025
Hi everyone,
I’m planning to automate my sauna using Loxone together with Kincony hardware.
My setup requires:
  • Two temperature sensors (sauna room and heater)
  • At least three relay outputs for sauna control (heater, ventilation, safety, etc.)
  • One or two relays for lighting
I already found some information in the forum about integrating the relay outputs with Loxone, which looks straightforward.
However, I’m still unsure about the OneWire temperature sensors – I know how to connect them to the Kincony board, but I don’t know how to get the temperature values into Loxone.
Would the KC868-A8 v3 board be a good choice for this setup, or is there another Kincony board that fits better?
Thanks in advance for your help and suggestions!
RE: Sauna automation with Loxone and Kincony - admin - 10-05-2025
for example , if you connect with DS18B20 sensor. use by KCS v3, will upload message to Loxone mini server by UDP command.
here is details: https://www.kincony.com/forum/showthread.php?tid=7264
RE: Sauna automation with Loxone and Kincony - evolova - 10-15-2025
Hi! The KC868-A8 v3 is fine for controlling your relays. For OneWire sensors, each GPIO usually handles only one sensor, so you might need multiple GPIOs or consider a KC868-A4 for more sensors. You can send the temperature data to Loxone via Kincony’s UDP protocol—works well in most setups.
