F4 ESP32-S3 IO pins define - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=62) +--- Forum: F4 (https://www.kincony.com/forum/forumdisplay.php?fid=98) +--- Thread: F4 ESP32-S3 IO pins define (/showthread.php?tid=8709) |
F4 ESP32-S3 IO pins define - admin - 11-03-2025 ANALOG_A1(0-5v) GPIO5 ANALOG_A2(0-5v) GPIO7 ANALOG_A3(4-20mA) GPIO6 ANALOG_A4(4-20mA) GPIO4 IIC SDA:GPIO8 IIC SCL:GPIO18 PCF8574:U23 i2c address:0x24 PCF8574->P0 (DI1) PCF8574->P1 (DI2) PCF8574->P2 (DI3) PCF8574->P3 (DI4) PCF8574->P4 (relay1) PCF8574->P5 (relay2) PCF8574->P6 (relay3) PCF8574->P7 (relay4) RF433MHz wireless receiver: GPIO40 ------------------------ Ethernet (W5500) I/O define: clk_pin: GPIO42 mosi_pin: GPIO43 miso_pin: GPIO44 cs_pin: GPIO41 interrupt_pin: GPIO2 reset_pin: GPIO1 -------------------- RS485: RXD:GPIO17 TXD:GPIO16 -------------------- Tuya module: RXD:GPIO38 TXD:GPIO39 Tuya network button: Tuya module's P28 Tuya network LED: Tuya module's P16 --------------------- 1-wire (pull-up resistance on PCB): 1-wire1:GPIO48 1-wire2:GPIO47 1-wire3:GPIO21 1-wire4:GPIO15 1-wire (without resistance on PCB): 1-wire2:GPIO14 ------------------------ SD Card: SPI-MOSI:GPIO10 SPI-SCK:GPIO11 SPI-MISO:GPIO12 SPI-CS:GPIO9 SPI-CD:GPIO13 ------------------------ 24C02 EPROM i2c address: 0x50 DS3231 RTC i2c address: 0x68 SSD1306 display: i2c address:0x3c |
