Help needed: Bricked A6 v1.3 board - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6 (https://www.kincony.com/forum/forumdisplay.php?fid=22) +--- Thread: Help needed: Bricked A6 v1.3 board (/showthread.php?tid=8974) |
Help needed: Bricked A6 v1.3 board - schma - 01-30-2026 Hi everyone, I'm seeking some technical advice on reviving an A6 v1.3 board (ESP32-based). The situation: The board was running ESPHome perfectly. However, following a Wi-Fi AP migration and some "beginner mistakes" within Home Assistant, I’ve lost all connectivity to the device. The problem:
Thanks in advance! RE: Help needed: Bricked A6 v1.3 board - admin - 01-31-2026 install USB driver firstly , then download firmware by USB-C cable. here is USB driver: https://www.kincony.com/download/CH341SER.zip RE: Help needed: Bricked A6 v1.3 board - schma - 01-31-2026 Thanks, but the driver is fine—I’ve already programmed a replacement (the exact same model) with it since then, and for the first time ESPHome needs wired connection. RE: Help needed: Bricked A6 v1.3 board - admin - 02-01-2026 tell us your order number, which store you bought. RE: Help needed: Bricked A6 v1.3 board - schma - 02-01-2026 Pm sent RE: Help needed: Bricked A6 v1.3 board - admin - 02-02-2026 your order number is not our official aliexpress store. our official aliexpress store is : https://kincony.aliexpress.com/store/1100463977 you can contact the seller re send you a new A6 pcb. they are our agent. |
