Digital input GND - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A32/A32 Pro (https://www.kincony.com/forum/forumdisplay.php?fid=27) +--- Thread: Digital input GND (/showthread.php?tid=9223) |
Digital input GND - Korenktom - 04-09-2026 Hello, I have a question about the wiring diagram of the Kincony KC868 A32 board. The board has 32 digital inputs, where each group of 8 inputs shares one GND pin. My question is: Does it matter which GND I use for the signal inputs, or do I need to follow a specific mapping - for example, inputs 1-8 only against the GND designated for that group? Or can I use just one GND pin for all 32 inputs? Thank you for clarification. RE: Digital input GND - admin - 04-09-2026 all GND in PCB is connected together, so GND pin for all 32 inputs. RE: Digital input GND - Korenktom - 04-10-2026 (04-09-2026, 11:21 PM)admin Wrote: all GND in PCB is connected together, so GND pin for all 32 inputs. Thanks you for your answer. |
