KC868-HA-V21 24v supply - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Getting Started with ESPHome and Home Assistant (https://www.kincony.com/forum/forumdisplay.php?fid=54) +--- Thread: KC868-HA-V21 24v supply (/showthread.php?tid=9374) |
KC868-HA-V21 24v supply - Gerrit - 05-30-2026 Hello, I am planning to use about 15 KC868-HA-V21 modules behind 6-gang momentary switches throughout my whole house and connect them to the KC868-AP dimmer board. The LED strips I am using are 24V. Can I also use this 24V supply to power the KC868-HA-V21 modules? The documentation states that it is supported, but I want to make sure it is a safe and reliable choice. Or, would it be better to use a separate 12V power supply for the modules? Thank you for your advice! RE: KC868-HA-V21 24v supply - admin - 05-30-2026 you should add extend power supply is better. if you want use HAv2 for KC868-AP, you need config ESPHome by yourself. RE: KC868-HA-V21 24v supply - Gerrit - 05-30-2026 (05-30-2026, 08:55 PM)admin Wrote: you should add extend power supply is better. if you want use HAv2 for KC868-AP, you need config ESPHome by yourself. RE: KC868-HA-V21 24v supply - admin - 05-31-2026 HAv2 use by 12V DC power is ok. here is video tour HAv2 work with home assistant: https://youtu.be/s5Htc43HqAc https://youtu.be/S679QX6Hc6I |
