RS485 issue - haipt2489 - 06-24-2026
Hi Kincony,
I have bought some of your B4M modules, and try to use the RS485 port.
I try to run the code here: https://www.kincony.com/forum/showthread.php?tid=8934
Code: /*
* RS485 Communication Test
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 39
#define RS485_TXD 38
while (!Serial);
// Send a test message
rs485Serial.println("Hello from KinCony B8M!");
// Wait for a short period
delay(1000);
String receivedMessage = "";
char c = rs485Serial.read();
receivedMessage += c;
// Print the received message
Serial.print("Received: ");
} else
Serial.println("RS485 is not available");
delay(2000);
but cannot receive the data from RS485 port. The log shows that port is not available.
Can you help me troubleshoot this issue?
Best regards,
Hai Pham
RE: RS485 issue - admin - 06-24-2026
take a photo of your arduino screen .
RE: RS485 issue - haipt2489 - 06-24-2026
you can download firmware BIN file directly to test.
https://www.kincony.com/forum/attachment.php?aid=9018
(06-24-2026, 11:18 AM)admin Wrote: you can download firmware BIN file directly to test.
esptool --baud 921600 --before default-reset --after hard-reset write-flash -u --flash-mode dio --flash-freq 80m --flash-size 16MB 0x0 4-RS485-Test.ino.merged.bin
esptool v5.1.0
Connected to ESP32-S3 on /dev/ttyACM0:
Chip type: ESP32-S3 (QFN56) (revision v0.2)
Features: Wi-Fi, BT 5 (LE), Dual Core + LP Core, 240MHz, Embedded PSRAM 8MB (AP_3v3)
Crystal frequency: 40MHz
USB mode: USB-Serial/JTAG
MAC: 28:84:85:85:e0:c8
Stub flasher running.
Changing baud rate to 921600...
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x003fffff...
Flash parameters set to 0x024f.
SHA digest in image updated.
Wrote 4194304 bytes at 0x00000000 in 21.9 seconds (1530.5 kbit/s).
Hash of data verified.
Hard resetting via RTS pin...
tomorrow i will test, then feedback to you.
RE: RS485 issue - admin - 06-25-2026
Code: /*
while (!Serial);
rs485Serial.println("Hello from KinCony");
delay(1000);
delay(2000);
make sure you have enabled "USB-CDC-On boot" option.
