KC868-A6 Lora - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6 (https://www.kincony.com/forum/forumdisplay.php?fid=22) +--- Thread: KC868-A6 Lora (/showthread.php?tid=9658) |
KC868-A6 Lora - Armsp0 - 07-23-2026 I have a KC868-6 V1.3 board. I live in New Zealand where AS923 requires 915Mhz frequency. Can the SX1262 board be used in place of the SX1278 module? Pinouts may be different firmware might need modification? RE: KC868-A6 Lora - admin - 07-23-2026 yes, you can replace with different frequency module, you can write your own arduino source code. KCS v2 not support to use lora. KCS v3 for KC868-A6v3 board support lora. RE: KC868-A6 Lora - Armsp0 - 07-23-2026 (07-23-2026, 10:12 AM)admin Wrote: yes, you can replace with different frequency module, you can write your own arduino source code. Sorry that my question may appear naive but does this mean I can upgrade the firmware of my V1.3 board to V3 to use Lora or must I replace my entire board with a V3 model RE: KC868-A6 Lora - admin - 07-23-2026 KCS v3 firmware MUST use KC868-A6v3 PCB (it's blue color pcb) |
