how to install home assistant for Pi5R32 beginner guide - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=89) +--- Forum: Pi5R32 (https://www.kincony.com/forum/forumdisplay.php?fid=110) +--- Thread: how to install home assistant for Pi5R32 beginner guide (/showthread.php?tid=9662) |
how to install home assistant for Pi5R32 beginner guide - admin - 07-24-2026 1. make home assistant OS SD card or SSD disk for KinCony Pi5R32. download https://www.raspberrypi.com/software/ 2. enable i2c for home assistant. Add files to enable I2C In the root of the hassos-boot partition, add a new folder called CONFIG. In the CONFIG folder, add another new folder called modules. Inside the modules folder add a text file called rpi-i2c.conf with the following content: i2c-dev In the root of the hassos-boot partition, edit the file called config.txt at last add two lines to it: dtparam=i2c_arm=on dtoverlay=i2c1-pi5,pins_2_3 Note: if you using Windows OS computer, you can use "DiskGenius.exe" free software to modify the files. Because Linux format file not visable on windows OS. 3. install HACS addon https://hacs.xyz/docs/use/download/download/#to-download-hacs-ossupervised 4. MCP23017 implementation for Home Assistant (HA) https://github.com/jpcornil-git/HA-mcp23017 5. KinCony SSD1306 I2C Display implementation for Home Assistant https://github.com/hzkincony/hass-ssd1306 6. KinCony ADS1115 ADC Sensor implementation for Home Assistant https://github.com/hzkincony/hass-ads1115 7. config yaml for MCP23017, ADS1115 install "file edit" add-on for HA , then config configuration.yaml https://www.kincony.com/forum/showthread.php?tid=9664 |
