KC868-A8v3 (KCS v3.27.4) – DS18B20 temperature value not showing in Loxone via UDP - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KinCony integrate with Loxone home automation (https://www.kincony.com/forum/forumdisplay.php?fid=19) +--- Thread: KC868-A8v3 (KCS v3.27.4) – DS18B20 temperature value not showing in Loxone via UDP (/showthread.php?tid=9970) |
KC868-A8v3 (KCS v3.27.4) – DS18B20 temperature value not showing in Loxone via UDP - Hakuna23 - 11-22-2026 Hello KinCony team, I am using a KC868-A8v3 with firmware KCS v3.27.4 connected to a Loxone Miniserver via UDP. What already works: • Controlling relays from Loxone (RELAY-SET-255,1,1\n) works fine. • Receiving relay feedback on UDP port 23456 (RELAY-SET-255,1,\h,OK) works fine. • Both DS18B20 sensors are properly configured in KCS (Sensor ID 1 on GPIO 40, Sensor ID 2 on GPIO 13) and show valid temperatures in the KCS web interface. My problem with the DS18B20 sensors in Loxone: 1. KCS does not automatically send DS18B20 temperature updates to Loxone via the UDP client. 2. When I poll the sensor from Loxone by sending RELAY-GET_SENSOR-255,1\n to UDP port 4196, the KC868-A8v3 replies in the Loxone UDP Monitor with: RELAY-GET_SENSOR-255,1,28,-100,OK 3. However, Loxone does not parse the temperature value into the Virtual UDP Input command. I have already tried the following command recognition strings (with "Use as digital input" unchecked): • RELAY-GET_SENSOR-255,1,\v,-100,OK • RELAY-GET_SENSOR-255,1,\v,\i,OK • RELAY-GET_SENSOR-255,1,\v, My questions: 1. What is the exact Command Recognition string required in Loxone Config to parse RELAY-GET_SENSOR-255,1,\v,? 2. Can KCS v3.27.4 send DS18B20 temperature changes automatically to the Loxone UDP client (port 23456) if I set a Threshold value > 0, or do sensors always have to be polled via RELAY-GET_SENSOR-255,x? Thank you very much for your help! |
