Whether KinCony have Aliexpress online store - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AI (https://www.kincony.com/forum/forumdisplay.php?fid=29) +--- Thread: Whether KinCony have Aliexpress online store (/showthread.php?tid=9975) |
Whether KinCony have Aliexpress online store - frlorenzon@gmail.com - 11-24-2026 Hello, I am planning to use a KC868-AI to read 34 pulse water meters (reed contact to GND, cables up to 32 m) and send the data to Home Assistant with ESPHome. Your sales team already confirmed that dry contact works (0 V = true, 12-24 V = false), that the board is powered by DC 12-24 V, and that 32 m cables are fine without extra resistors. My questions below are in order of importance: 1) PCF8574 sampling and shortest pulse: the 48 inputs are read through six PCF8574 expanders (I2C on GPIO4/GPIO5). Is the INT pin of each PCF8574 connected to any ESP32 GPIO, or are the inputs only polled over I2C? With ESPHome polling, what is the shortest pulse (closed contact time) you have tested and detected reliably on all 48 inputs? 2) Input circuit and ground: from the schematic, each input uses an EL357 optocoupler with a 2K series resistor and the common side is the 12VIN rail. Can you confirm that the field side shares the same GND as the ESP32 logic (non-isolated buck converter), and that a reed contact between INPUT_Dx and GND is the intended wiring? With a 24 V supply the LED current will be about 11 mA per closed input. Is that acceptable for long-term use, or do you recommend powering the board at 12 V? 3) ESPHome YAML: is there an official, tested YAML for the KC868-AI with all 48 inputs (PCF8574 addresses 0x21 to 0x26, mode INPUT, inverted: true) that I can use as a base? Which firmware / hardware revision does the pin definition in thread 2016 correspond to? 4) I2C speed: which I2C frequency do you recommend for the six PCF8574 chips in ESPHome (50, 100 or 400 kHz)? Is there any known issue reading all six at the same time with Ethernet enabled? 5) Debounce in KCS v2: the KCS v2 page does not describe any input debounce time. Is there a configurable input debounce / delay time in KCS v2 for the KC868-AI? If yes, what are its unit, range and default value? (The KCS v3 manual mentions an 'input delayed time' setting, also without unit.) 6) Pulse counter: does KCS v2 (or any KinCony firmware for the KC868-AI) have a built-in pulse counter per input that is kept after a power cycle? I plan to count in ESPHome and store counters in flash, but I would like to know if there is a ready solution. 7) Analog inputs: the KC868-AI has no analog inputs, only free GPIOs 34, 35, 36 and 39. For a second project (4-20 mA / 0-5 V water level sensors) which KinCony board do you recommend, and does it work well with ESPHome? Thank you very much for your help. Best regards, Felipe Lorenzon (Brazil) RE: Whether KinCony have Aliexpress online store - admin - 11-24-2026 1: PCF8574 INT pin not used for ESP32. 2: all PCB GND is same. 3: the esphome yaml file in forum can be used. 4: 100Khz. 5: debounce option only use in KCS v3. 6: that need use by ESPHome. 7: you can select product by this tool: https://mq.kincony.com/qq/product/product-selector |
