Reading Eastron SDM630 via RS485 (Sensor -> Modbus) - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=87) +--- Forum: N60 (https://www.kincony.com/forum/forumdisplay.php?fid=88) +--- Thread: Reading Eastron SDM630 via RS485 (Sensor -> Modbus) (/showthread.php?tid=9982) |
Reading Eastron SDM630 via RS485 (Sensor -> Modbus) - buttom3 - 11-30-2026 Hello, I am trying to read an external Eastron SDM630 power meter (Slave 1, 9600 bps, 8N1) connected to the RS485 port (A-A, B-B) of my KinCony N60 (KCS v3.27.4) and forward it to Home Assistant via MQTT. I configured Sensor 1 as "Modbus" (Slave 1, FC04, Reg 0, float32, ABCD), saved, and rebooted, but the Monitor tab shows "-- V" and the meter's communication icon never blinks. I also noticed "Protocol -> Modbus Master" only lists "Modbus TCP" (no RS485). 1. Does the N60's RS485 port support Modbus RTU Master mode for "Sensor -> Modbus", or is it fixed as a Modbus Slave port? 2. If supported, what baud rate does it use (9600 or 38400) and is any extra setting needed? Thanks! |
