09-09-2025, 02:17 AM
friendly_name: dm16
board: esp32-s3-devkitc-1
type: arduino
ota:
platform: esphome
web_server:
port: 80
type: W5500
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
text_sensor:
- platform: ethernet_info
ip_address:
name: ESP IP Address
address_0:
name: ESP IP Address 0
address_1:
name: ESP IP Address 1
address_2:
name: ESP IP Address 2
address_3:
name: ESP IP Address 3
address_4:
name: ESP IP Address 4
dns_address:
name: ESP DNS Address
mac_address:
name: ESP MAC Address
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());
uart:
rx_pin: 4
tx_pin: 6
baud_rate: 115200
stop_bits: 1
data_bits: 8
parity: NONE
debug:
modbus:
modbus_controller:
- address: 1
update_interval: 5s
output:
# CH1 (0x0FA0 / 4000)
- platform: modbus_controller
address: 0x0FA0
value_type: U_WORD
write_lambda: |-
// state = 0.0 ~ 1.0 → 0 ~ 4095
uint16_t reg = (uint16_t) round(x * 4095.0);
return reg;
# CH2 (0x0FA1 / 4001)
address: 0x0FA1
value_type: U_WORD
write_lambda: |-
return reg;
# CH3
address: 0x0FA2
value_type: U_WORD
write_lambda: |-
return reg;
# CH4
address: 0x0FA3
value_type: U_WORD
write_lambda: |-
return reg;
# CH5
address: 0x0FA4
value_type: U_WORD
write_lambda: |-
return reg;
# CH6
address: 0x0FA5
value_type: U_WORD
write_lambda: |-
return reg;
# CH7
address: 0x0FA6
value_type: U_WORD
write_lambda: |-
return reg;
# CH8
address: 0x0FA7
value_type: U_WORD
write_lambda: |-
return reg;
# CH9
address: 0x0FA8
value_type: U_WORD
write_lambda: |-
return reg;
# CH10
address: 0x0FA9
value_type: U_WORD
write_lambda: |-
return reg;
# CH11
address: 0x0FAA
value_type: U_WORD
write_lambda: |-
return reg;
# CH12
address: 0x0FAB
value_type: U_WORD
write_lambda: |-
return reg;
# CH13
address: 0x0FAC
value_type: U_WORD
write_lambda: |-
return reg;
# CH14
address: 0x0FAD
value_type: U_WORD
write_lambda: |-
return reg;
# CH15
address: 0x0FAE
value_type: U_WORD
write_lambda: |-
return reg;
# CH16
address: 0x0FAF
value_type: U_WORD
write_lambda: |-
return reg;
# 16 Channel Dimmer
light:
- platform: monochromatic
output: dac_ch1_out
default_transition_length: 0s
output: dac_ch2_out
output: dac_ch3_out
output: dac_ch4_out
output: dac_ch5_out
output: dac_ch6_out
output: dac_ch7_out
output: dac_ch8_out
output: dac_ch9_out
output: dac_ch10_out
output: dac_ch11_out
output: dac_ch12_out
output: dac_ch13_out
output: dac_ch14_out
output: dac_ch15_out
output: dac_ch16_out
- id: 'pcf8574_hub_in_1' # for input channel 1-16
i2c_id: bus_a
address: 0x22
pcf8575: true
pcf8574: pcf8574_hub_in_1
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 4
number: 5
number: 6
number: 7
ads1115:
- address: 0x48
- platform: ads1115
multiplexer: 'A0_GND'
gain: 6.144
resolution: 16_BITS
update_interval: 5s
- platform: ads1115
multiplexer: 'A1_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A2_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A3_GND'
gain: 6.144
update_interval: 5sesphome yaml file download:
DM16-HA-without Tuya.txt (Size: 9.49 KB / Downloads: 126)
