03-03-2022, 12:31 AM
(This post was last modified: 03-03-2022, 01:02 AM by udayansarma.)
(03-03-2022, 12:23 AM)admin Wrote: H32BS' MOSFET is output high level, if you want to output low level. you can let H32BS connect to KC868-E16, E16 relay's COM connect with Ground. when Turn ON relay, then output 0V.
Got it. Thanks
(03-03-2022, 12:31 AM)udayansarma Wrote:(03-03-2022, 12:23 AM)admin Wrote: H32BS' MOSFET is output high level, if you want to output low level. you can let H32BS connect to KC868-E16, E16 relay's COM connect with Ground. when Turn ON relay, then output 0V.
Got it. Thanks
Tried it with E16 relays and it all worked. Thanks much
