Switch terminal board H16B relay default controll
Thanks, I have successfully connected via the serial port on the host to the VM and can see the messages. However sometimes the state character is dropped. Mostly I receive "RELAY-KEY-255,1,1" and intermittently I get "RELAY-KEY-255,1,". It worked 100% of the time via the H16B so I'll check further.
If I use the Plastic Momentary Wall Switch Panel as a dry contact at 230v what current will it switch? Looking at using connected to a Shelly Dimmer if I can't get the serial to be reliable.
RE: Switch terminal board H16B relay default controll - by T920919 - 10-27-2022, 04:28 AM
