Differences in protocols between H32B and H32B Pro?
I want to use a H32B and a H32B Pro with Home assistant.
For the H32B, I used this unofficial integration: https://github.com/fiLLLip/hass-components-sha. It uses the RELAY-SET- and RELAY-READ- commands; you can see the code here https://github.com/fiLLLip/hass-componen..._init__.py. This works very well.
The same code does not work for H32B Pro. Only about 50% of clicks on switches work, and I often get error messages such as 'Failed to call service switch/turn_on. 'NoneType' object has no attribute 'group''.
Is this normal? Do the H32B and the H32B Pro use different protocols? I found the page for the protocol used in H32B, is it not supposed to work the same on the Pro?
Thank you!
Differences in protocols between H32B and H32B Pro? - by lulu01 - 03-30-2024, 08:34 PM
