Problem with DS1307 on KC868-A6
#11
(08-19-2024, 11:05 PM)admin Wrote: your code already is running correctly. you can also install DS1307 arduino library, then chose a example demo run testing.
I cannot believe you confirm my code is running correctly. A NAK answer after a Write Request to 0x68H is an evidence something is wrong in the hardware. Furthermore, if the scanner only sees both PCF8574 but not the DS1307 is a confirmation that I2C is working but the DS1307 don't.
I replaced the DS1307 chip on the PCB and now it is working as expected.
Thank you.
Problem with DS1307 on KC868-A6 - by Ramalcu - 08-13-2024, 07:11 PM
RE: Problem with DS1307 on KC868-A6 - by admin - 08-13-2024, 11:04 PM
RE: Problem with DS1307 on KC868-A6 - by Ramalcu - 08-14-2024, 12:50 AM
RE: Problem with DS1307 on KC868-A6 - by admin - 08-14-2024, 07:57 AM
RE: Problem with DS1307 on KC868-A6 - by Ramalcu - 08-14-2024, 09:04 AM
RE: Problem with DS1307 on KC868-A6 - by admin - 08-14-2024, 12:56 PM
RE: Problem with DS1307 on KC868-A6 - by Ramalcu - 08-15-2024, 06:37 AM
RE: Problem with DS1307 on KC868-A6 - by admin - 08-15-2024, 12:52 PM
RE: Problem with DS1307 on KC868-A6 - by Ramalcu - 08-19-2024, 07:47 PM
RE: Problem with DS1307 on KC868-A6 - by admin - 08-19-2024, 11:05 PM
RE: Problem with DS1307 on KC868-A6 - by Ramalcu - 08-20-2024, 10:57 PM
RE: Problem with DS1307 on KC868-A6 - by admin - 08-20-2024, 11:42 PM
RE: Problem with DS1307 on KC868-A6 - by Ramalcu - 08-21-2024, 05:26 AM
RE: Problem with DS1307 on KC868-A6 - by admin - 08-21-2024, 07:41 AM
RE: Problem with DS1307 on KC868-A6 - by sconcina - 09-04-2024, 09:18 PM
RE: Problem with DS1307 on KC868-A6 - by admin - 09-04-2024, 11:03 PM
RE: Problem with DS1307 on KC868-A6 - by sconcina - 09-05-2024, 03:55 PM
RE: Problem with DS1307 on KC868-A6 - by admin - 09-05-2024, 11:44 PM
RE: Problem with DS1307 on KC868-A6 - by Sean - 12-22-2024, 09:29 AM
RE: Problem with DS1307 on KC868-A6 - by admin - 12-22-2024, 11:10 AM
