using 5v-12v as input sensor
Question
hi all
I would like to use IR Photoelectric Switch such as :  PNP, Normally Open sensor. E3F-DS30P1
Ideally, I would use the 12v from the A6 board to power the IR switch, I'm only concerned about the output of the switch...
Can I connect it safely to one of the Digital inputs or Analog inputs?
The E3D-DS30P1 will output the exact same voltage as it get's on it's the vcc leg when it detects an object.
thanks!
https://www.bing.com/search?q=PNP%2C+Nor...E3F-DS30P1
using 5v-12v as input sensor - by amararsa24s - 09-08-2024, 11:05 AM
RE: using 5v-12v as input sensor - by admin - 09-08-2024, 11:26 AM
RE: using 5v-12v as input sensor - by amararsa24s - 09-09-2024, 07:08 PM
RE: using 5v-12v as input sensor - by amararsa24s - 09-09-2024, 06:10 PM
RE: using 5v-12v as input sensor - by admin - 09-09-2024, 11:03 PM
RE: using 5v-12v as input sensor - by amararsa24s - 09-10-2024, 07:32 AM
RE: using 5v-12v as input sensor - by amararsa24s - 09-11-2024, 05:08 PM
RE: using 5v-12v as input sensor - by admin - 09-11-2024, 11:42 PM
RE: using 5v-12v as input sensor - by amararsa24s - 09-12-2024, 06:31 AM
RE: using 5v-12v as input sensor - by amararsa24s - 09-14-2024, 11:11 PM
RE: using 5v-12v as input sensor - by tanoshimi - 02-01-2025, 03:01 PM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 12:13 AM
RE: using 5v-12v as input sensor - by admin - 02-02-2025, 12:39 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 09:28 AM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 10:04 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 10:26 AM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 10:35 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 10:44 AM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 11:21 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 07:47 PM
RE: using 5v-12v as input sensor - by twostar - 02-03-2025, 03:44 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-03-2025, 07:56 AM
RE: using 5v-12v as input sensor - by admin - 02-03-2025, 05:32 AM
RE: using 5v-12v as input sensor - by twostar - 02-03-2025, 05:35 AM
