09-16-2024, 01:13 AM
1. motion sensor have 4 wires, two are dc12v power supply, you can use by your KC868-A16's power supply. another 2 wires just connect to digital input port of KC868-A16 and GND..
2. about siren, just chose to buy DC12v version siren, so that you can let KC868-A16 mosfet output drive siren directly. Because of the mosfet we designed by MAX 10A, it's enough for siren to use, you not need to use a extend power supply for siren.
3. the home assistant server MUST connect with your router, just if you don't want use KC868-A16 by ethernet cable. you can use RS485 cable conenct to your home assistant server's RS485 port. Such as if you use KinCony Server-Mini or Server16 Pi controller, there is a RS485 port, it can drive relay board by RS485 cable. Just integrate KC868-A16 to home assistant by modbus component using ESPHome. We have YouTube video tour for that.
