DM16 ESPHome yaml for home assistant with tuya
  friendly_name: dm16
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
    type: arduino
external_components:
  - source:
      type: git
      ref: v1.2.0
  baud_rate: 0
  hardware_uart: UART0
ota:
  platform: esphome
web_server:
  port: 80
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());
uart:
  - id: dac_uart
    rx_pin: 4
    tx_pin: 6
    baud_rate: 115200
    stop_bits: 1
    data_bits: 8
    parity: NONE
  - id: tuya_mcu_uart
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: qdmpkznox0g9kkvo
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
modbus:
  - uart_id: dac_uart
modbus_controller:
  - address: 1
    update_interval: 5s
output:
  # CH1 (0x0FA0 / 4000)
  - platform: modbus_controller
    address: 0x0FA0
    value_type: U_WORD
    write_lambda: |-
      // state = 0.0 ~ 1.0 → 0 ~ 4095
      uint16_t reg = (uint16_t) round(x * 4095.0);
      return reg;
  # CH2 (0x0FA1 / 4001)
    address: 0x0FA1
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH3
    address: 0x0FA2
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH4
    address: 0x0FA3
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH5
    address: 0x0FA4
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH6
    address: 0x0FA5
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH7
    address: 0x0FA6
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH8
    address: 0x0FA7
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH9
    address: 0x0FA8
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH10
    address: 0x0FA9
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH11
    address: 0x0FAA
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH12
    address: 0x0FAB
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH13
    address: 0x0FAC
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH14
    address: 0x0FAD
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH15
    address: 0x0FAE
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH16
    address: 0x0FAF
    value_type: U_WORD
    write_lambda: |-
      return reg;
# 16 路 Light (调光灯)
light:
  - platform: monochromatic
    output: dac_ch1_out
    default_transition_length: 0s
  - platform: tuya_wifi_mcu
    name: "Tuya DAC CH1"
    # bind other light, sync state
    bind_light_id: light_1
    output: dac_ch1_out
    dp_id: 2
    # hide from homeassistant ui
    internal: true
    output: dac_ch2_out
    name: "Tuya DAC CH2"
    bind_light_id: light_2
    output: dac_ch2_out
    dp_id: 8
    internal: true
    output: dac_ch3_out
    name: "Tuya DAC CH3"
    bind_light_id: light_3
    output: dac_ch3_out
    dp_id: 16
    internal: true
    output: dac_ch4_out
    name: "Tuya DAC CH4"
    bind_light_id: light_4
    output: dac_ch4_out
    dp_id: 101
    internal: true
    output: dac_ch5_out
    name: "Tuya DAC CH5"
    bind_light_id: light_5
    output: dac_ch5_out
    dp_id: 102
    internal: true
    output: dac_ch6_out
    name: "Tuya DAC CH6"
    bind_light_id: light_6
    output: dac_ch6_out
    dp_id: 103
    internal: true
    output: dac_ch7_out
    name: "Tuya DAC CH7"
    bind_light_id: light_7
    output: dac_ch7_out
    dp_id: 104
    internal: true
    output: dac_ch8_out
    name: "Tuya DAC CH8"
    bind_light_id: light_8
    output: dac_ch8_out
    dp_id: 105
    internal: true
    output: dac_ch9_out
    name: "Tuya DAC CH9"
    bind_light_id: light_9
    output: dac_ch9_out
    dp_id: 106
    internal: true
    output: dac_ch10_out
    name: "Tuya DAC CH10"
    bind_light_id: light_10
    dp_id: 107
    internal: true
    output: dac_ch11_out
    name: "Tuya DAC CH11"
    bind_light_id: light_11
    dp_id: 108
    internal: true
    output: dac_ch12_out
    name: "Tuya DAC CH12"
    bind_light_id: light_12
    dp_id: 109
    internal: true
    output: dac_ch13_out
    name: "Tuya DAC CH13"
    bind_light_id: light_13
    dp_id: 110
    internal: true
    output: dac_ch14_out
    name: "Tuya DAC CH14"
    bind_light_id: light_14
    dp_id: 111
    internal: true
    output: dac_ch15_out
    name: "Tuya DAC CH15"
    bind_light_id: light_15
    dp_id: 112
    internal: true
    output: dac_ch16_out
    name: "Tuya DAC CH16"
    bind_light_id: light_16
    dp_id: 113
    internal: true
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
      pcf8574: pcf8574_hub_in_1
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 4
      number: 5
      number: 6
      number: 7
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
esphome yaml file download:
.txt   DM16-HA-with-Tuya.txt (Size: 13.11 KB / Downloads: 124)
DM16 ESPHome yaml for home assistant with tuya - by admin - 09-09-2025, 02:39 AM
