[arduino code examples for B2]-11 digital INPUT trigger OUTPUT directly
   Made by KinCony IoT
   https://www.kincony.com
   Demo: KinCony B2 DI Control Relay
   Board: KinCony B2 (ESP32)
   Digital Input 1 -> GPIO6
   Digital Input 2 -> GPIO7
   Relay 1 -> GPIO4
   Relay 2 -> GPIO46
// Digital Inputs
#define DI1_PIN 6
#define DI2_PIN 7
// Relay Outputs
#define RELAY1_PIN 4
#define RELAY2_PIN 46
// Relay logic (Active LOW)
#define RELAY_ON  LOW
#define RELAY_OFF HIGH
// Store previous DI states
int lastDI1State;
int lastDI2State;
void setup()
  // Configure digital inputs
  pinMode(DI1_PIN, INPUT);
  pinMode(DI2_PIN, INPUT);
  // Configure relay outputs
  pinMode(RELAY1_PIN, OUTPUT);
  pinMode(RELAY2_PIN, OUTPUT);
  // Turn OFF relays at startup
  digitalWrite(RELAY1_PIN, RELAY_OFF);
  digitalWrite(RELAY2_PIN, RELAY_OFF);
  // Read initial input states
  lastDI1State = digitalRead(DI1_PIN);
  lastDI2State = digitalRead(DI2_PIN);
void loop()
  // Read current DI states
  int di1State = digitalRead(DI1_PIN);
  int di2State = digitalRead(DI2_PIN);
  // DI1 changed
  if (di1State != lastDI1State)
    lastDI1State = di1State;
    if (di1State == HIGH)
      digitalWrite(RELAY1_PIN, RELAY_ON);
    else
  // DI2 changed
  if (di2State != lastDI2State)
    lastDI2State = di2State;
    if (di2State == HIGH)
      digitalWrite(RELAY2_PIN, RELAY_ON);
    else
  // Small delay for stability
  delay(10);
arduino ino file download:
.zip   11-input-trigger-output.zip (Size: 728 bytes / Downloads: 146)
.zip   11-input-trigger-output.ino.merged.zip (Size: 180 KB / Downloads: 150)
[arduino code examples for B2]-11 digital INPUT trigger OUTPUT directly - by admin - 07-25-2026, 06:40 AM
