  • 1 Vote(s) - 5 Average
"KCS" firmware STRING protocol document
Note: This protocol document use for KinCony ESP32 smart controller:
KC868-A4 KC868-A6  KC868-A8 KC868-A8S KC868-A16 KC868-E16S KC868-A32 KC868-A64 KC868-A128 smart controller
Different board will have different channel of digital output, digital input , ADC, DAC, so the protocol is same , just according to the hardware resource to set channel number.
.pdf   KC868-A-series-protocol-String.pdf (Size: 135.93 KB / Downloads: 918)
(01-22-2023, 09:00 AM)admin Wrote: Note: This protocol document use for KinCony ESP32 smart controller:
FANTASTIC !!!
Need only BIN firmware file now.
you can download BIN file at this link: https://www.kincony.com/forum/showthread.php?tid=2536
"2023 new "KCS" firmware for KinCony ESP32 board detailed explanation" video tour at here: https://youtu.be/gJTUb1SGnII
Dear,
String protocol cannot be activated for RS485 communication.  WHY?
This could be a great feature.
Please let see if this option can be activated.
Thanks & Regards.
Dear Admin,
I am testing STRING protocol on TCP, is working very well.
Please can you make it available on RS485 communication?
MODBUS-RTU seems not working well, would like to use STRING on RS485.
Thanks & Regards.
RS485 use by MODBUS protocol, what problem with you of MODBUS testing? you can take a photo of your test screen. so that i can see what command you have sent.
does string protocol work on KC868-AI, please?
My settings:
UDP Client: enable
remote address:255.255.255.255 (I have also tried server IP address 10.0.0.136)
Port: 9876
The Input port connects to GND. The monitoring page shows input green.
I have a PC (IP 10.0.0.136) with Wireshark, the firewall is turned off, but I don't see any traffic. I turn the input on and off.
TCP client periodically sends something if I turn it on and monitor it, but it's just establishing a connection
when next Monday we begin to work, we can check it.
Ok, thanks.
Do you plan to publish the source code for KCS?
"KCS" not have open source plan now.
