Is any way to link elecyric gate motor and wireless security alarm to use kincony app
Is any way to link electrc gate motor and wireless security alarm to use kincony app?
The wirless security alarm is :-  SL6 Response Wirefree Telecommunicating Alarm System 868 MHZ
And the electric gate motor is 433MHZ RF , i attached the specifications and details
.pdf   207-SM-Control-panel-for-swing-gates-12VDC-and-24VDC.pdf (Size: 2.08 MB / Downloads: 927)
.pdf   sl5.pdf (Size: 1.23 MB / Downloads: 477)
you can see this video, may be is your wanted. just short for relay controller's sensor input ports, then will send alarm message to your mobile phone.
The gate motor is RF 433MHZ, is any way to learn to kincony and open, close the gate from the same app?
do you gate motor receiver PCB board or controller have a "learn" function button?
Yes, the remote control is 433 MHZ learn function button.
ok, use KC868-G wireless gateway to send RF 433MHz signal. you can use kincony smart home app create a "RF" button, when press the "button" on phone will send a RF signal, then let your gate motor pcb board "learn" the signal to remember it.
Where the KC868- G wirless will be located
Baring in mind the gate automation panel on the house fence outdoor .
not far away from your gate receiver module. near by it. KC868-G only connect with a USB cable for DC5V power supply is ok.
Not sure the best location of the KC-868-G
The gate receiver is close to gate on the fence.
All controllers will be in garden switchboard.
let KC868-G distance with your receiver board <10 meter.
