11-07-2024, 11:49 PM
work well now?
[Arduino IDE demo source code for KC868-A16]--#08-PCF8574-DO
work well now?
12-07-2024, 03:56 PM
Hello, I have a KC868-A16 board, which I am new to. I want to use Arduino IDE because I know it. When connecting the KC868 board by USB-C to my PC (board powered or not powered with an external 12V power supply, is the same), nothing happens; I cannot see any Colm port with my Arduino IDE. So, please tell me how to connect the board and which board I should choose for my Arduino IDE. Thank you.
12-07-2024, 11:46 PM
take a photo how you wire of your KC868-A16.
in arduino IDE chose "NodeMCU-32S"
01-08-2025, 12:01 PM
Hi
I have similar problem I can not turn on or off the relay. my code : I use platform IO and framework arduino #include "PCF8574.h" #include <Wire.h> #define Input_IIC_address 0x21 #define Input_IIC_address 0x22 #define Relay_IIC_address 0x24 #define Relay_IIC_address 0x25 GPIO_I2C gpioI2C; // Set i2c address PCF8574 pcf8574_input_1(Input_IIC_address,4,5); PCF8574 pcf8574_input_2(Input_IIC_address,4,5); PCF8574 pcf8574_relay_1(Relay_IIC_address,4,5); PCF8574 pcf8574_relay_2(Relay_IIC_address,4,5); void GPIO_I2C::Init() { #if ( PROFILE_COMPILE & GPIO_I2C_MODULE) PRINT_LOG_API_PrintDebug("Init()..", MODULE_NAME, __LINE__); byte count = 0; Wire.begin(4, 5); for (byte i = 8; i < 120; i++) { Wire.beginTransmission (i); // Begin I2C transmission Address (i) if (Wire.endTransmission () == 0) // Receive 0 = success (ACK response) { Serial.print ("Found address: "); Serial.print (i, DEC); Serial.print (" (0x"); Serial.print (i, HEX); // PCF8574 7 bit address Serial.println (")"); break; } } //Wire.begin(); // Initialize I2C communication // Wire.setClock(100000); // Set I2C clock to 100kHz (default is 400kHz) pcf8574_relay_1.pinMode(P0, OUTPUT); pcf8574_relay_1.pinMode(P1, OUTPUT); pcf8574_relay_1.pinMode(P2, OUTPUT); pcf8574_relay_1.pinMode(P3, OUTPUT); pcf8574_relay_1.pinMode(P4, OUTPUT); pcf8574_relay_1.pinMode(P5, OUTPUT); pcf8574_relay_1.pinMode(P6, OUTPUT); pcf8574_relay_1.pinMode(P7, OUTPUT); pcf8574_relay_2.pinMode(P0, OUTPUT); pcf8574_relay_2.pinMode(P1, OUTPUT); pcf8574_relay_2.pinMode(P2, OUTPUT); pcf8574_relay_2.pinMode(P3, OUTPUT); pcf8574_relay_2.pinMode(P4, OUTPUT); pcf8574_relay_2.pinMode(P5, OUTPUT); pcf8574_relay_2.pinMode(P6, OUTPUT); pcf8574_relay_2.pinMode(P7, OUTPUT); pcf8574_input_1.pinMode(P0, INPUT); pcf8574_input_1.pinMode(P1, INPUT); pcf8574_input_1.pinMode(P2, INPUT); pcf8574_input_1.pinMode(P3, INPUT); pcf8574_input_1.pinMode(P4, INPUT); pcf8574_input_1.pinMode(P5, INPUT); pcf8574_input_1.pinMode(P6, INPUT); pcf8574_input_1.pinMode(P7, INPUT); pcf8574_input_2.pinMode(P0, INPUT); pcf8574_input_2.pinMode(P1, INPUT); pcf8574_input_2.pinMode(P2, INPUT); pcf8574_input_2.pinMode(P3, INPUT); pcf8574_input_2.pinMode(P4, INPUT); pcf8574_input_2.pinMode(P5, INPUT); pcf8574_input_2.pinMode(P6, INPUT); pcf8574_input_2.pinMode(P7, INPUT); if (pcf8574_relay_1.begin()) { Serial.println("pcf8574_relay_1 OK"); } else { Serial.println("pcf8574_relay_1 not OK"); } Serial.print("Init pcf8574_2..."); if (pcf8574_relay_2.begin()) { Serial.println("pcf8574_relay_2 OK"); } else { Serial.println("pcf8574_relay_2 NOT OK"); } } void setup() { gpioI2C.Init(); } void loop() { gpioI2C.TestOutputP1(); } Please help me to active these lines
01-08-2025, 12:30 PM
because you have wrong wire. do you have the 9 bit green terminal, there are two point label "12V", you should connect with your power supply terminal.
01-09-2025, 04:07 PM
Users browsing this thread: |
1 Guest(s) |
