  • 1 Vote(s) - 5 Average
[Arduino IDE demo source code for KC868-A16]--#08-PCF8574-DO
#11
work well now?
Hello, I have a KC868-A16 board, which I am new to. I want to use Arduino IDE because I know it. When connecting the KC868 board by USB-C to my PC (board powered or not powered with an external 12V power supply, is the same), nothing happens; I cannot see any Colm port with my Arduino IDE. So, please tell me how to connect the board and which board I should choose for my Arduino IDE. Thank you.
take a photo how you wire of your KC868-A16.
in arduino IDE chose "NodeMCU-32S"
Hi
I have similar problem
I can not turn on or off the relay.
my code :
I use platform IO and framework  arduino
 #include "PCF8574.h"
#include <Wire.h>
#define Input_IIC_address 0x21
#define Input_IIC_address 0x22
#define Relay_IIC_address 0x24
#define Relay_IIC_address 0x25
GPIO_I2C gpioI2C;
// Set i2c address
PCF8574 pcf8574_input_1(Input_IIC_address,4,5);
PCF8574 pcf8574_input_2(Input_IIC_address,4,5);
PCF8574 pcf8574_relay_1(Relay_IIC_address,4,5);
PCF8574 pcf8574_relay_2(Relay_IIC_address,4,5);
void GPIO_I2C::Init()
#if ( PROFILE_COMPILE & GPIO_I2C_MODULE)
    PRINT_LOG_API_PrintDebug("Init()..", MODULE_NAME, __LINE__);
    byte count = 0;
    Wire.begin(4, 5);
  for (byte i = 8; i < 120; i++)
    Wire.beginTransmission (i);          // Begin I2C transmission Address (i)
    if (Wire.endTransmission () == 0)  // Receive 0 = success (ACK response)
      Serial.print ("Found address: ");
      Serial.print (i, DEC);
      Serial.print (" (0x");
      Serial.print (i, HEX);    // PCF8574 7 bit address
      Serial.println (")");
      break;
    //Wire.begin();  // Initialize I2C communication
  // Wire.setClock(100000); // Set I2C clock to 100kHz (default is 400kHz)
    pcf8574_relay_1.pinMode(P0, OUTPUT);
    pcf8574_relay_1.pinMode(P1, OUTPUT);
    pcf8574_relay_1.pinMode(P2, OUTPUT);
    pcf8574_relay_1.pinMode(P3, OUTPUT);
    pcf8574_relay_1.pinMode(P4, OUTPUT);
    pcf8574_relay_1.pinMode(P5, OUTPUT);
    pcf8574_relay_1.pinMode(P6, OUTPUT);
    pcf8574_relay_1.pinMode(P7, OUTPUT);
    pcf8574_relay_2.pinMode(P0, OUTPUT);
    pcf8574_relay_2.pinMode(P1, OUTPUT);
    pcf8574_relay_2.pinMode(P2, OUTPUT);
    pcf8574_relay_2.pinMode(P3, OUTPUT);
    pcf8574_relay_2.pinMode(P4, OUTPUT);
    pcf8574_relay_2.pinMode(P5, OUTPUT);
    pcf8574_relay_2.pinMode(P6, OUTPUT);
    pcf8574_relay_2.pinMode(P7, OUTPUT);
    pcf8574_input_1.pinMode(P0, INPUT);
    pcf8574_input_1.pinMode(P1, INPUT);
    pcf8574_input_1.pinMode(P2, INPUT);
    pcf8574_input_1.pinMode(P3, INPUT);
    pcf8574_input_1.pinMode(P4, INPUT);
    pcf8574_input_1.pinMode(P5, INPUT);
    pcf8574_input_1.pinMode(P6, INPUT);
    pcf8574_input_1.pinMode(P7, INPUT);
    pcf8574_input_2.pinMode(P0, INPUT);
    pcf8574_input_2.pinMode(P1, INPUT);
    pcf8574_input_2.pinMode(P2, INPUT);
    pcf8574_input_2.pinMode(P3, INPUT);
    pcf8574_input_2.pinMode(P4, INPUT);
    pcf8574_input_2.pinMode(P5, INPUT);
    pcf8574_input_2.pinMode(P6, INPUT);
    pcf8574_input_2.pinMode(P7, INPUT);
    if (pcf8574_relay_1.begin())
        Serial.println("pcf8574_relay_1 OK");
    else
        Serial.println("pcf8574_relay_1 not OK");
    Serial.print("Init pcf8574_2...");
    if (pcf8574_relay_2.begin())
        Serial.println("pcf8574_relay_2 OK");
    else
        Serial.println("pcf8574_relay_2 NOT OK");
void setup()
    gpioI2C.Init();
void loop()
    gpioI2C.TestOutputP1();
Please help me to active these lines
because you have wrong wire. do you have the 9 bit green terminal, there are two point label "12V", you should connect with your power supply terminal.
(01-08-2025, 12:30 PM)admin Wrote: because you have wrong wire. do you have the 9 bit green terminal, there are two point label "12V", you should connect with your power supply terminal.
can you take my image and edit it due to your answer ? I don't understand your answer
