Threads: 1
I have problem when I import.
Imported unrecognised types:
* ui_switch
* iu_group
* ui_tab
Threads: 1,046
before import flows , you need install these nodes for Node-Red:
1. node-red-contrib-ui-led 【LED UI】
2. node-red-contrib-ui-level 【Temperature】
3. node-red-dashboard 【dashboard UI】
Threads: 0
I'm getting an error message after installing , missing ui-base.
6 Apr 14:14:11 - [info] Waiting for missing types to be registered:
26 Apr 14:14:11 - [info] - ui_base
What should I do?
Threads: 1,046
Threads: 0
I have imported the flow to node red, changed the IP address and port of the TCP nodes.
How can I get these switches on the dashboard?
