KC868-Server integrate to home asssitant by MQTT configuration.yaml
KC868-Server 16 channel output, 16 channel digital input, 4 channel analog input all use in configuration.yaml
.txt   KC868-Server-home-assistant-config.txt (Size: 8.15 KB / Downloads: 865)
Note: xxxxxxxxxxxxxxxxxxxxxxxx is UID of controller, just replace with your device UID. You can find the UID in ethernet setting.
(03-27-2022, 04:52 AM)admin Wrote: KC868-Server 16 channel output, 16 channel digital input, 4 channel analog input all use in configuration.yaml
I got it all to show in overview, but it does nothing to the leds.
yaml is good, server setup is good, mqtt config is good, all are aligned... use no good.
Huh
.txt   kincony 2.25.23.txt (Size: 16.98 KB / Downloads: 516)
try to replace your password: Mauscom1$ not use "$" for a test. such as password= Mauscom1
still not helping the situation.
(02-26-2023, 04:11 AM)admin Wrote: try to replace your password: Mauscom1$  not use "$" for a test. such as password=  Mauscom1
add whatsapp number: +86-15381188302 when have free time, use "anydesk" we remote control your computer have a look.
(02-27-2023, 07:41 AM)admin Wrote: add whatsapp number: +86-15381188302 when have free time, use "anydesk" we remote control your computer have a look.
What is your anydesk ID?
I have the same problem what should i do please
what's your problem details?
The same problem above with (member Mauscom) KC868-Server 16 channel output, 16 channel digital input, 4 channel analog input all use in configuration.yaml
It happens with the exact same pictures shown above.
show "unknow" in dashboard?
