  • 1 Vote(s) - 5 Average
Lesson19 - add water level sensor for automation in home assistant
#14
(10-08-2023, 10:36 PM)admin Wrote: i am not use your sensor output what signal. But if you want to monitor water level, usually we will use analog water level sensor. or float switch water level sensor, here is webpage: https://www.aliexpress.com/item/2251832805783103.html
I have tried to make a water level indicator without the use of a company Sensor
I have tested it in my water tank and it is working but need your feedback which help me a lot
I have attached a Word file - with the name - Water Level Indication - (Diagram, steps)
on the basis of Binary Input-1, Input-2 ( on | off ) Status of LED, I will try to make an automation script for the Turn On | Off Relay used for the water pump
Thanks in Advance for checking and your feedback valuable to me
.docx   Water Level Indicator.docx (Size: 1.17 MB / Downloads: 540)
Thanks & Regards,
Arshad Abbas
Smile
RE: Lesson19 - add water level sensor for automation in home assistant - by ARSHAD - 10-09-2023, 10:07 AM
