  • 2 Vote(s) - 5 Average
Configure KC868-A8 in ESPHome
#21
I'm trying to configure one of the relays on the board as a momentary relay, but I can't get the configuration right.
according to ESPHome the code should be
toggle:
  -platform: gpio
    pin: 25
    icon: "mdi:gate"
    on_turn_on:
    - delay: 500ms
    - switch.turn_off: relay
I have tried to adapt it to my configuration for relay 1 of the KC868-A8 board.
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      on_turn_on:
        - delay: 500ms
but I can't get rid of the error "on_turn_on" is an invalid option for Pin
Could you help me configure it?
Thanks in advance
here is sample config for KC868-A8 input1 trigger output1:
platform: ESP32
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
address: 0x24
address: 0x22
mode: OUTPUT
on_press:
then:
- switch.toggle: light1
pcf8574: pcf8574_hub_in_1
