07-08-2022, 07:40 AM
Configure KC868-A8 in ESPHome
07-08-2022, 09:07 AM
you are welcome, KinCony will support great technical support.
10-04-2022, 08:43 PM
Hello, I am trying to configure pins A1 and A2 of a KC868-A8 board, but I do not see the configuration of these pins in the file that you have published, please can you guide me to configure them in ESPhome
Thanks in advance
10-04-2022, 10:13 PM
sensor: - platform: adc pin: 34 name: "analog-1" update_interval: 10s attenuation: 11db - platform: adc pin: 35 name: "analog-2" update_interval: 10s attenuation: 11db
11-16-2022, 08:42 AM
I would like to configure an input for count my water with pulse_counter with a KC868-a8, I Have a contact dry between GND and Input 0, with a Binary_sensor, it's ok , but I can't count it with ESPHOME in Home Assistant with a sensor. I Think I don't have the correct PIN, I Try all from 0 to 39, But Nothing... Do you have an idea ? Thanks This is my configuration in HA : esphome: name: kc868-a8 platform: ESP32 board: esp32dev # Example configuration entry for ESP32 i2c: sda: 4 scl: 5 scan: true id: bus_a # Example configuration entry ethernet: type: LAN8720 mdc_pin: GPIO23 mdio_pin: GPIO18 clk_mode: GPIO17_OUT phy_addr: 0 # Optional manual IP manual_ip: static_ip: 192.168.0.199 gateway: 192.168.0.1 subnet: 255.255.255.0 # Example configuration entry pcf8574: - id: 'pcf8574_hub_output' address: 0x24 - id: 'pcf8574_hub_input' address: 0x22 sensor: - platform: pulse_counter pin: number: 21 inverted: true mode: input: true pullup: true name: "Pulse Counter"
11-16-2022, 12:48 PM
digital input 1-8 can use for dry contact sensor. but whether ESPHome can calculate the pulse number, i have not tested. if ESPHome support and make sure what your water sensor pulse frequency, whether esp32 gpio speed fast enough.
11-16-2022, 02:41 PM
(11-16-2022, 12:48 PM)admin Wrote: digital input 1-8 can use for dry contact sensor. but whether ESPHome can calculate the pulse number, i have not tested. if ESPHome support and make sure what your water sensor pulse frequency, whether esp32 gpio speed fast enough. For digital input it's simple, it's a binary_sensor and the platform is - platform: gpio and pin is 0,1, 2.... But for - platform: pulse_counter what is the way to configure the PIN ? 0,1,2 doesn't oK Who can have a configuration for pulse_counter on K868-A8 on Home assistant ? Thanks Binary sensor -> simple pcf8574: - id: 'pcf8574_hub_output' address: 0x24 - id: 'pcf8574_hub_input' address: 0x22 binary_sensor: - platform: gpio name: "input1" pin: pcf8574: pcf8574_hub_input # Use pin number 0 number: 0 # One of INPUT or OUTPUT mode: INPUT inverted: false - platform: gpio name: "input2" pin: pcf8574: pcf8574_hub_input # Use pin number 0 number: 1 # One of INPUT or OUTPUT mode: INPUT inverted: false But for pulse_counter, for input 0,1,2,3.... ? sensor: - platform: pulse_counter update_interval: 2s pin: number: 21 inverted: true mode: input: true pullup: true name: "Pulse Counter"
11-16-2022, 02:59 PM
https://esphome.io/components/sensor/pulse_counter.html
here ESPHome showed MAX can use 8 channel for counter. maybe you need to set "count_mode". A8's input by Optocoupler circuit, so check your sensor pulse speed, whether is too fast.
11-16-2022, 03:53 PM
(11-16-2022, 02:59 PM)admin Wrote: https://esphome.io/components/sensor/pulse_counter.html I know this article, but that doesn't explain which pin is for input 0, 1, etc For Pin12 by exemple, what is the real input on K868-A8 ? I have only one Counter to install, I put it between GND and Input 0, but how to configure it ? PIN 12 : Nothing.... Thanks
11-17-2022, 12:10 AM
i think maybe you can't connect directly by digital input of A8, because A8's digital input use by PCF8574 IIC extend chip, so i asked you what your water pulse sensor's speed, PCF8574 refresh input port need time.
you can try to connect with these ports: DS18B20/DHT11/DHT21/LED strip -1: GPIO14 DS18B20/DHT11/DHT21/LED strip -2: GPIO13 DS18B20/DHT11/DHT21/LED strip -2: GPIO32 DS18B20/DHT11/DHT21/LED strip -2: GPIO33 such as connect with GPIO14, it's connect with ESP32 pin directly, just have a pull up resistance.
| 1 Guest(s) |
