I tried to update esp home server but I can't upload yaml file. I don't know why. ESP sever showing offline. I used 3 network cables. 2 are on KC868 server and 1 is connecting on A128.
Please give me some advice.
Thank you!
Updating /config/esphome/kc868-server.yaml
INFO ESPHome 2023.11.6
INFO Reading configuration /config/esphome/kc868-server.yaml...
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
See
https://esphome.io/guides/faq.html#why-a...pping-pins
See
WARNING GPIO15 is a strapping PIN and should only be used for I/O with care.
See
See
INFO Generating C++ source...
INFO Compiling app...
Processing a128 (board: esp32dev; framework: arduino; platform: platformio/espressif32@5.4.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Wire @ 2.0.0
RAM: [= ] 11.2% (used 36744 bytes from 327680 bytes)
Flash: [=== ] 33.9% (used 622121 bytes from 1835008 bytes)
========================= [SUCCESS] Took 11.32 seconds =========================
INFO Successfully compiled program.
ERROR Cannot upload Over the Air as the config does not include the ota: component
======== [ERROR] /config/esphome/kc868-server.yaml ========
======================== [SUMMARY] ========================
- /config/esphome/kc868-server.yaml: FAILED
