KC868-A6 Outputs
Hi Kincony
I have a relayboard that turns relay on when pin goes to GND.  I see A16 digital outputs go high when turned on....Can I invert this to make actuve GND ?
Thankyou..Peter
it according to your arduino IDE code.
I am using homeassistant.....how should I configure the output in the YAML to drive the output to ground ?
Thankyou
if you use home assistant, i think you are using ESPHome. just add "inverted: true" in your pins.
number: 25
(09-14-2022, 05:22 AM)admin Wrote: if you use home assistant, i think you are using ESPHome. just add "inverted: true" in your pins.
      number: 25
Hello
I dont have a circuit diagram for the v.5 A16 board.  I think you've set it up to turn the led on when the output goes to 12V.  I have just tried inverted: false and the LED doesnt work.  Can you please share the circuit diagram so I can have a look...
Thankyou
https://www.kincony.com/download/KC868-A...ematic.pdf
