09-17-2022, 11:37 PM
Does the power meter measure battery DC voltage? If not, can you add it as a sensor to measure DC voltage?
Power meter with DC battery voltage?
09-17-2022, 11:38 PM
what DC voltage range you want to test?
09-18-2022, 05:18 AM
09-18-2022, 11:59 AM
it's very high, i think you can find a voltage meter.
09-18-2022, 11:09 PM
09-19-2022, 12:09 AM
our board only work for DC 0-5v input, so you need to use a coverter circuit, but 600V ,it's too large.
09-19-2022, 08:00 AM
(This post was last modified: 09-19-2022, 08:03 AM by thundercat.)
(09-19-2022, 12:09 AM)admin Wrote: our board only work for DC 0-5v input, so you need to use a coverter circuit, but 600V ,it's too large. Do have converter boards that you can recommend for something smaller like 0-60v or 0-100v? I'm planning on using it to measure battery voltage on a 48v DC battery on a solar system, but would also be nice to have the flexibility in range for other projects aside from solar. The idea is if the voltage parameter is lower than 45v then trigger the on-grid relay. Once voltage reaches 48v turn off the grid relay.
09-19-2022, 08:46 AM
you can search some DC voltage detector module, that range DC 0-250v, you can set if voltage < XXX value, then relay ON, if voltage > YYY value, then relay OFF. such as follows:
09-19-2022, 04:47 PM
09-19-2022, 09:51 PM
you are welcome.
| 1 Guest(s) |
