KinCony-TUYA_ESP32_Adapter ESP32 arduino source code
#21
Hi, Is there code available for 16 outputs: (KC868-H16) ?
you can use for KC868-H16 by tcp connection, but need modify the code, because H16 only have 16 channel relay.
(01-12-2024, 12:24 AM)admin Wrote: you can use for KC868-H16 by tcp connection, but need modify the code, because H16 only have 16 channel relay.
Thanks for reply
Is it possible to disable or delete "ALL ON" and "ALL OFF" commands on the app?
sorry, can't do that.
I have a Kincony-ESP32-Tuya adaptor with Arduino source code installed.
This is connected by RS232 to KC868-H32B smart controller.
I’m using Tuya Smart App and everything works OK.
My question:  Is it possible to modify the code to disable or delete “All On” and “All Off” commands?
sure, this you can do, just delete ALL ON and ALL OFF arduino code. I though you want remove the ALL ON / ALL OFF ico button from tuya app, that can't.
I'm not very experienced with arduino code so how do I delete ALL ON and ALL OFF from the code
Hi, can anyone help me with this - I want to delete ALL OFF and ALL ON from arduino code.
