01-17-2023, 10:53 AM
(This post was last modified: 01-17-2023, 11:15 AM by stanchiam.
Edit Reason: edit
I tried turning on and off without any problem, esphome is working.
But when i check the board, the output led does not light up when i turn it on.
Below are the yaml i used, is there anything missing or wrong that causes the led not to light up when i switch it on using esphome?
Btw i have not connect or use any DC12/24v input yet.
# Example configuration entry for output input channel 1-16
address: 0x24
address: 0x25
address: 0x21
address: 0x22
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
Ops, connecting 12v DC Input by looping from the power, the led light up
address: 0x24
address: 0x25
address: 0x21
address: 0x22
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
