02-16-2023, 07:55 PM
I was able to connect my hb868 32 pro to my local mqtt.
I have few questions
1. the mqtt broker seems to work only on wifi - when I try to configure the local ip on the ethernet interface it does not change the default ip. is this the case?
2. is it possible to configure a feedback on mqtt of the pressed button? like, when I press my switch 3 to send an mqtt message that relay3 is on.
3. how can I configure the behavior for multiple clicks?
Thank you!
Thank you!
