подключение KC868-Server Ethernet WiFi CM4 + KC868-H32B Pro-2
#15
it as same as your H32B Pro, just change the topic, for example (this config demo for output1 of KC868-Server, you just replace UID by yourself):
mqtt:
  - name: 'output-1'
    unique_id: output-1
    state_topic: 'server/8ae082ec66f37db231cf2b8f/state'
    command_topic: 'server/8ae082ec66f37db231cf2b8f/set'
    payload_on:  '{"relay1":{"on":1}}'
    payload_off:  '{"relay1":{"on":0}}'
    state_on: 1
    state_off: 0
here is sample config file for KC868-Server yaml.
.txt   KC868-Server-home-assistant-MQTT_config_202212.txt (Size: 9.26 KB / Downloads: 340)
RE: подключение KC868-Server Ethernet WiFi CM4 + KC868-H32B Pro-2 - by admin - 02-23-2024, 01:24 AM
