Are the Other GPIO available in any way on the board ?
I would like to access the other GPIOs if possible.
are other gpio available on the board or is i2c expander the only way ?
thanks
what device you want to connected? such as temperature sensor? or .... ?
Mainly PIR motion sensors, but does it matter ?
There are 2 DI , you can use for your PIR sensor.
Thank you, yeah i am using those 2 already Smile
What i need to know is if any of the other GPIO that the esp32 chipset support is available so i can connect more than 2 PIR Sensors or if using `i2c` is my only option
thanks
