KinCony KC868-AP Modbus using in Esphome not working
i am trying to configure a Light/humidity/temperature modbus sensor with kincony Ap modbus port in esphome. below is my configuration and sensor data sheet is attached,I am getting this error in the esphome logs
"No response recieved removed from send queue"
Can point what I am doing wrong.
  friendly_name: Kincony-Esp32-Dimmer
    type: arduino
  encryption:
    key: "7p6IWmIbZjSt7YFWX2bKaCBB1bTmhraTZo+P4cV7BoE="
ota:
  password: "2aa38947ee1ec3376d4e0b941ce919da"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Kincony-Esp32-Dimmer"
    password: "uIm62IkfOTJ0"
captive_portal:
web_server:
  port: 80
#Modbus Configuration for Sensors
uart:
  tx_pin: GPIO33
  rx_pin: GPIO14
  baud_rate: 9600
modbus:
  uart_id: mbus
  send_wait_time: 200ms
modbus_controller:
- id: light_sensor1
  address: 1
  modbus_id: modbus1
  update_interval: 1s
# ethernet:
#   type: LAN8720
#   mdc_pin: GPIO23
#   mdio_pin: GPIO18
#   clk_mode: GPIO17_OUT
#   phy_addr: 0
  sda: 4
  scl: 16
  - id: 'pcf8574_hub_in_1'  # for input channel 1-8    maybe 0x22  /  0x3A
    address: 0x3A
    address: 0x21
  - platform: modbus_controller
    modbus_controller_id: light_sensor1
    name: "Light Intensity"
    address: 0x02
    unit_of_measurement: "Lux" ## for any other unit the value is returned in minutes
    register_type: read
    value_type: U_WORD
    accuracy_decimals: 1
    address: 0x01
    unit_of_measurement: "C" ## for any other unit the value is returned in minutes
    register_type: read
    value_type: U_WORD
    address: 0x00
    unit_of_measurement: "%" ## for any other unit the value is returned in minutes
    register_type: read
    value_type: U_WORD
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_2
      number: 4
      number: 5
      number: 6
      number: 7
      number: 34
      number: 35
pca9685:
    frequency: 500
output:
  - platform: pca9685
    pca9685_id: 'pca9685_hub'
    channel: 0
  - platform: pca9685
    channel: 1
  - platform: pca9685
    channel: 2
  - platform: pca9685
    channel: 3
  - platform: pca9685
    channel: 4
  - platform: pca9685
    channel: 5
  - platform: pca9685
    channel: 6
  - platform: pca9685
    channel: 7
  - platform: pca9685
    channel: 8
  - platform: pca9685
    channel: 9
  - platform: pca9685
    channel: 10
  - platform: pca9685
    channel: 11
  - platform: pca9685
    channel: 12
  - platform: pca9685
    channel: 13
  - platform: pca9685
    channel: 14
  - platform: pca9685
    channel: 15
light:
  - platform: monochromatic
    output: PWM0
    output: PWM1
    output: PWM2
    output: PWM3
    output: PWM4
    output: PWM5
    output: PWM6
    output: PWM7
    output: PWM8
    output: PWM9
    output: PWM10
    output: PWM11
    output: PWM12
    output: PWM13
    output: PWM14
    output: PWM15
  - platform: rgbw
    red: PWM1
    green: PWM2
    blue: PWM3
    white: PWM4
    pin: 13
    inverted: false
    pin: 2
    inverted: false
.pdf   CWT-SL Light sensor (RS485 type) Manual.pdf (Size: 458.11 KB / Downloads: 1,835)
KinCony KC868-AP Modbus using in Esphome not working - by nikhuge - 06-21-2023, 09:59 PM
