04-05-2024, 08:13 AM
I load the firmware KCS_KC868_A16_V2.2.2.bin, but when enable MQTT flag I can't change the default ip broker 192.168.1.100. And after enabled MQTT I don't see anymore the KC868-A16 in the lan
"KCS" v2 firmware MQTT protocol document
04-05-2024, 08:53 AM
"I can't change the default ip broker 192.168.1.100", take a photo how can't change?
04-05-2024, 11:03 AM
(04-05-2024, 08:53 AM)admin Wrote: "I can't change the default ip broker 192.168.1.100", take a photo how can't change?
04-05-2024, 12:06 PM
why can't input? use mouse click the edit section, then input. if you can't , take a video , send to whatsapp number: +86-15381188302
04-05-2024, 03:38 PM
04-05-2024, 07:47 PM
Greetings! I noticed something strange! If the MQTT protocol is enabled, and the MQTT server is not reachable, the response becomes very slow! If I click fast on some OUTPUT, it takes at least 5-7 seconds until the command is processed! There is normal?
Thx in advance!
04-05-2024, 10:08 PM
(04-05-2024, 03:38 PM)GibKat Wrote:(04-05-2024, 12:06 PM)admin Wrote: why can't input? use mouse click the edit section, then input. if you can't , take a video , send to whatsapp number: +86-15381188302 Gray is a prompt message, why don't you try clicking with the mouse and then entering the information????
04-05-2024, 10:09 PM
(04-05-2024, 07:47 PM)Jackson Wrote: Greetings! I noticed something strange! If the MQTT protocol is enabled, and the MQTT server is not reachable, the response becomes very slow! If I click fast on some OUTPUT, it takes at least 5-7 seconds until the command is processed! There is normal? how many protocol type you have enabled? suggest disable some unused protocol.
Online Store: https://shop.kincony.com Alibaba Store: https://kincony.en.alibaba.com/ (04-05-2024, 10:09 PM)admin Wrote:(04-05-2024, 07:47 PM)Jackson Wrote: Greetings! I noticed something strange! If the MQTT protocol is enabled, and the MQTT server is not reachable, the response becomes very slow! If I click fast on some OUTPUT, it takes at least 5-7 seconds until the command is processed! There is normal? Hey again, i have 1 protocol enabled, MQTT! After disabling MQTT, the Module working fine!
04-06-2024, 12:39 AM
sir good day..
i still cannot connect the binary input of my a16s board to my home assistant vis mqtt. can you please check my code sir ? =) binary_sensor: - name: 'input-1' unique_id: input-1 state_topic: KC868_A16S/E05A1B5A547C/STATE value_template: '{{ value_json.input_1.on }}' payload_on: 1 payload_off: 0 .... i have been trying differrent code but still no luck. advise sir.. thank you |
