KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome
#25
(12-18-2023, 11:09 PM)admin Wrote: can you post the newest yaml with latest KC868-HA component (v3.0.0).
  friendly_name: dingtian-4ch
    type: arduino
  baud_rate: 0
  encryption:
    key: "XXX"
ota:
  password: "XXX"
status_led:
    number: GPIO15
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 9600
  type: JL1101
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  clk_mode: GPIO17_OUT
  # The PHY chip has a pin labeled TX_EN that goes to GPIO 21 on ESP
  # and the RSTn pin on the phy goes to GPIO0
  # Datasheet indicates the RSTn should be LOW to disable the phy and default is high
  power_pin: GPIO0
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-kc868-ha
      ref: main
kc868_ha:
  - platform: kc868_ha
    target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
    switch_adapter_addr: 10 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
    bind_output: 1
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
RE: KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome - by gizmo - 12-18-2023, 11:13 PM
