Turn Wi-Fi Off
Is it possible to turn Wi-Fi completely off by any way (software or hardware)? I’d like to use my KC868-H32B controller in mqtt ethernet mode with radio module completely turned off.
login with your wifi webpage, set work mode="STA", save and reboot. Then will not for use, until you do wifi reset.
another hardware way is short for wifi reset button two pin , wifi will down.
