08-09-2021, 03:19 AM
improvement:
Enable Wifi and Ethernet use MQTT at the same time. Now you can use KC868-H32B connect to two different MQTT broker. Every relay output or input port state changed, will send message to 2 MQTT brokers.
download the ZIP file , unzip update the bin file for KC868-H32B relay controller by USB-RS232 cable.
Relay32_V435_210807.zip (Size: 45.13 KB / Downloads: 278)
firmware update tool download: https://www.kincony.com/download/KC868-C...loader.zip
