Threads: 918
A24 use DC12v power supply, digital input port support MAX 12V level.
Threads: 2
hello!
I have an esp32 based Kincony A24 panel. I need another modbus port besides the original one. it has a uart port for the 4G cellular adapter. i use this to control a uart pwm generator. is it possible to connect the pwm panel and the modbus adapter to the uart Tx and Rx connectors in parallel, but connect the 5v voltage separately, only to one panel at a time? I would normally use the modbus, but if necessary, I disconnect it with one of the relays, turn on the pwm, modify what I need, then disconnect it and reconnect the modbus panel.
Threads: 918
sorry, i don't understand what you want to do, can you draw a diagram, easy to understand.
Threads: 918
ok, i see. i think it's OK, you can remove the 4G module, then use the RXD,TXD for modbus ports. just make sure your 5V load current <1A, if large current is not good for A24 circuit.
