Time control not working
#11
UTC issue will fix in next update version.
(01-02-2025, 10:38 PM)puterboy Wrote: I have the same problem!
UTC time offsets are incorrect and inconsistent
- On one board, UTC-N give UTC-(N+1). E.g., I am in Americas/New_York which is now on EST which is UTC-5 but when set to UTC-5, the time reads as UTC-4
- On another board, when set to UTC-5, it shows UTC-13
Also the display of time (under `index.html`) is non-standard. Specifically, it doesn't force 2 digits for the display of seconds, minutes (or hours).
For example: 4:07:05 reads as: 4:7:5 which I have never seen.
This should be a pretty simple bug in the code to correct as it just requires the correct arithmetic to add/subtract from UTC hours plus the correct formatting of the time printout.
Note I am using FW 2.2.10
which board model you are using? i send you a new firmware.
KC868-A16
Thank you.
you can test with this new firmware fixed time zone issue. after you tested, you can give me a result.
.zip   KCS_KC868_A16_V2.2.12.zip (Size: 763.79 KB / Downloads: 378)
The same problem with KC868_AI. Instead of UTC+1 I need to setup UTC+8 to have correct time.
here is new firmware for KC868-AI, you can test it.
.zip   KCS_KC868_AI_V2.2.12.zip (Size: 753.73 KB / Downloads: 380)
(01-06-2025, 10:54 AM)admin Wrote: you can test with this new firmware fixed time zone issue. after you tested, you can give me a result.
i can confirm firmware A16_2.2.12 fixed the UTC time issue for me. Thanks!
ok
Hello, I also had problems with setting the timer, after uploading New v2.2.12 A16 the problem disappeared but a new one appeared, there is no sensors tab
(01-09-2025, 07:10 PM)luzik1978 Wrote: Hello, I also had problems with setting the timer, after uploading New v2.2.12 A16 the problem disappeared but a new one appeared, there is no sensors tab
take a photo of your problem.
