I have a KC868-A16S with the following code on it , After installing it it now will not respond,
the relays will only activate via the on board push button not via home assistant interface?
Home assistant show the switch turn on but the board does nothing.
I there any suggestion why this is happing ?
Dose the code look ok and can I reset the board and reload the firmware.
friendly_name: ESPHome IO Board
type: arduino
ota:
safe_mode: true
password: !sectet ota_password
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.168.1.3
gateway: 192.168.1.1
subnet: 255.255.255.0
address: 0x24
address: 0x25
address: 0x21
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
inverted: false
inverted: false
inverted: false
inverted: false
number: 4
inverted: false
number: 5
inverted: false
number: 6
inverted: false
number: 7
inverted: false
pcf8574: pcf8574_hub_in_2
number: 8
inverted: false
number: 9
inverted: false
number: 10
inverted: false
number: 11
inverted: false
number: 12
inverted: false
number: 13
inverted: false
number: 14
inverted: false
number: 15
inverted: false
