Tuya adapter V2 arduino source code - RS485 temperature humidity sensor
let your own RS485 temperature and humidity sensor can work with Tuya app, so that can remote monitor sensor data and make AUTOMATION by Tuya app via internet.
arduino source code donwload:
.zip   Tuya_AdapterV2_RS485_Temper_Hum.zip (Size: 1.98 KB / Downloads: 153)
#include <ModbusMaster.h>
#include <Arduino.h>
#include <TuyaWifi.h>
#include "HardwareSerial.h"
//---------RS485 setting
#define DEBUG   1
#define SERIAL_BAUD   9600
#define RX_PIN    32
#define TX_PIN    33
#define SERIAL_NUM  2
#define SLAVE_ADDR  1
#define READ_ADDR  0
#define READ_NUM   2
HardwareSerial My485Serial(SERIAL_NUM);
ModbusMaster node;
uint16_t rcv_buf[READ_NUM] = {0};
float get_value[2] = {0.0};
/* Current device DP values */
int temperature = 0;
int humidity = 0;
static void ReadInputRegs(void)
  uint8_t result = node.readInputRegisters(READ_ADDR, READ_NUM);
  if (result == node.ku8MBSuccess) {//if communicate successful then
    #if DEBUG
    Serial1.print("Result:");
    #endif
    for (uint8_t j = 0; j < READ_NUM; j++)
      rcv_buf[j] = node.getResponseBuffer(j);
      #if 0 ///just for debug.
      Serial1.print(" 0x");
      Serial1.print( rcv_buf[j], HEX );//display data in hex.
      #endif
    get_value[0] = rcv_buf[0]/10;///huminity
    get_value[1] = rcv_buf[1]/10;///temperature
    temperature = rcv_buf[0];
    humidity = get_value[1];
    #if DEBUG
    Serial1.print("humi.<");
    Serial1.print(get_value[1]);
    Serial1.print("%>");
    Serial1.print(" temp.<");
    Serial1.print(get_value[0]);
    Serial1.println("°c>");
    #endif
    //delay(300);
  else
    node.clearResponseBuffer();
//---RS485 setting end----
TuyaWifi my_device;
/* Current LED status */
unsigned char led_state = 0;
int key_pin = 25;
/* Data point define */
#define DPID_TEMP_CURRENT     1
#define DPID_HUMIDITY_CURRENT 2
#define LED_WiFi  26
//#define LED_User  33
*                                     dp type(TuyaDefs.h) : DP_TYPE_RAW, DP_TYPE_BOOL, DP_TYPE_VALUE, DP_TYPE_STRING, DP_TYPE_ENUM, DP_TYPE_BITMAP
unsigned char dp_array[][2] =
  {DPID_TEMP_CURRENT, DP_TYPE_VALUE},
  {DPID_HUMIDITY_CURRENT, DP_TYPE_VALUE},
unsigned char pid[] = {"dpyditdgaadmqw8m"};
/* last time */
unsigned long last_time = 0;
void setup()
  My485Serial.begin(SERIAL_BAUD, SERIAL_8N1, RX_PIN, TX_PIN); //RS485 serial port
  node.begin(SLAVE_ADDR,My485Serial);
  Serial.begin(9600,SERIAL_8N1,22,19);  //Tuya module serial port
  Serial1.begin(115200,SERIAL_8N1,3,1);   //USB serial port
  // Serial with tuyawifi
  pinMode(LED_WiFi, OUTPUT);
  digitalWrite(LED_WiFi, LOW);
/*  pinMode(LED_User, OUTPUT);
  digitalWrite(LED_User, LOW);*/
  //Initialize networking keys.
  my_device.init(pid, mcu_ver);
  my_device.set_dp_cmd_total(dp_array, 2);
  //delay(300);
  last_time = millis();
void loop()
  ReadInputRegs();  // read RS485 sensor
  my_device.uart_service();
  //Enter the connection network mode when Pin7 is pressed.
    delay(80);
      if (led_state == LOW) {
        led_state = HIGH;
      } else {
        led_state = LOW;
      digitalWrite(LED_WiFi, led_state);
  /* report the temperature and humidity */
  if ((my_device.mcu_get_wifi_work_state() == WIFI_CONNECTED) || (my_device.mcu_get_wifi_work_state() == WIFI_CONN_CLOUD)) {
    my_device.mcu_dp_update(DPID_TEMP_CURRENT, temperature, 1);
    my_device.mcu_dp_update(DPID_HUMIDITY_CURRENT, humidity, 1);
  delay(1000);
* @param {unsigned char} dpid
* @return {unsigned char}
  /* all DP only report */
  return TY_SUCCESS;
* @param {*}
* @return {*}
void dp_update_all(void)
Hello there. I just received my Tuya adapter V2, and flashed the exactly same code (copy-paste) to read my xy-md02 sensor via Arduino IDE. Although i get the corrent readings on my usb to rs485 sensor (when querying the sensor with modscan32), on IDE's serial monitor i get Result:humi.<221.00%> temp.<0.00°c>. Can you plz help me troubleshoot my issue?
because different sensor have different protocol, you need to modify source code according to your sensor's protocol.
After a lot of searching and studying i managed to get the right values to the serial monitor. My problem now is that in smartlife/tuya app i get the correct value only for temperature. Humidity is stuck in 26%. Sensor is 100% responsive in serial monitor and tuya app as well. DP_IDs used are 1 for temp and 2 for hum. Can you help me troubleshoot please?
these two command use for upload sensor data. you can change the vaule upload to tuya app, check whether work well.
By changing the following i recieved the correct updated humidity value. Thank you once again!
my_device.mcu_dp_update(DPID_HUMIDITY_CURRENT, humidity, 2);
ok, good.
